Need BIOS Dump for MD61701 ( AKOYA S14401 )
8 ANTWORTEN 8
AlexS
Nachricht 1 von 9
1.265 Aufrufe
Nachricht 1 von 9
1.265 Aufrufe
Dear friend! Pls help with work dump or link to download original bios for MD61701 ( MSN 30027842)
Tags (1)
8 ANTWORTEN 8
Igor28
Nachricht 2 von 9
1.261 Aufrufe
Nachricht 2 von 9
1.261 Aufrufe
Hi @AlexS,
Could you please give us the current BIOS version and the reason why you would like to update the BIOS?
Kind regards
AlexS
Nachricht 3 von 9
1.259 Aufrufe
Nachricht 3 von 9
1.259 Aufrufe
After Win update, Laptop not start. 0,59А, no image on screen. I change ME but, nothing change
Igor28
Nachricht 4 von 9
1.257 Aufrufe
Nachricht 4 von 9
1.257 Aufrufe
Hi @AlexS ,
I recommend contacting Medion Support for assistance with this issue.
The technical team will provide you with the necessary instructions.
Kind regards,
AlexS
Nachricht 5 von 9
1.255 Aufrufe
Nachricht 5 von 9
1.255 Aufrufe
thanks, but i ca't find directly  link to ontact with support
Igor28
Nachricht 6 von 9
1.253 Aufrufe
Nachricht 6 von 9
1.253 Aufrufe
@AlexS ,
May I kindly ask which country you are located in, so that I can provide you with the appropriate contact information?
AlexS
Nachricht 7 von 9
1.250 Aufrufe
Nachricht 7 von 9
1.250 Aufrufe
Belarus
Igor28
Nachricht 8 von 9
1.246 Aufrufe
Nachricht 8 von 9
1.246 Aufrufe
@AlexS ,
There is no dedicated contact information for Belarus. However, I will try to assist you in resolving this issue.
Perform a Static Discharge:
Please disconnect the laptop from the charger and remove all accessories.
Then, press and hold the power button for 60 seconds.
Afterwards, reconnect the charger, power on the laptop, and check if the issue persists.
Check Display and Connections:
If possible, connect an external monitor via HDMI or VGA to verify whether the laptop outputs video externally.
Additionally, if you feel comfortable opening the device, please reseat or inspect the internal display cable (LVDS/eDP) for any loose connections.
Does the laptop itself turn on, is there any fan noise, or does the keyboard turn on?
AlexS
Nachricht 9 von 9
1.243 Aufrufe
Nachricht 9 von 9
1.243 Aufrufe
))) I check all of this ) I mean that my laptop fix on 0,59 Amp use and no any post. Batt CMOS reset. I change Intel ME in my dump to new and clear. I mean that i have some skeels. I ask about work dump or original full image drom producent
8 ANTWORTEN 8
