Need BIOS Dump for MD61701 ( AKOYA S14401 )
8 RÉPONSES 8
AlexS
Message 1 sur 9
1 360 Visites
Message 1 sur 9
1 360 Visites
Dear friend! Pls help with work dump or link to download original bios for MD61701 ( MSN 30027842)
Balises (1)
8 RÉPONSES 8
Igor28
Message 2 sur 9
1 356 Visites
Message 2 sur 9
1 356 Visites
Hi @AlexS,
Could you please give us the current BIOS version and the reason why you would like to update the BIOS?
Kind regards
AlexS
Message 3 sur 9
1 354 Visites
Message 3 sur 9
1 354 Visites
After Win update, Laptop not start. 0,59А, no image on screen. I change ME but, nothing change
Igor28
Message 4 sur 9
1 352 Visites
Message 4 sur 9
1 352 Visites
Hi @AlexS ,
I recommend contacting Medion Support for assistance with this issue.
The technical team will provide you with the necessary instructions.
Kind regards,
AlexS
Message 5 sur 9
1 350 Visites
Message 5 sur 9
1 350 Visites
thanks, but i ca't find directly  link to ontact with support
Igor28
Message 6 sur 9
1 348 Visites
Message 6 sur 9
1 348 Visites
@AlexS ,
May I kindly ask which country you are located in, so that I can provide you with the appropriate contact information?
AlexS
Message 7 sur 9
1 345 Visites
Message 7 sur 9
1 345 Visites
Belarus
Igor28
Message 8 sur 9
1 341 Visites
Message 8 sur 9
1 341 Visites
@AlexS ,
There is no dedicated contact information for Belarus. However, I will try to assist you in resolving this issue.
Perform a Static Discharge:
Please disconnect the laptop from the charger and remove all accessories.
Then, press and hold the power button for 60 seconds.
Afterwards, reconnect the charger, power on the laptop, and check if the issue persists.
Check Display and Connections:
If possible, connect an external monitor via HDMI or VGA to verify whether the laptop outputs video externally.
Additionally, if you feel comfortable opening the device, please reseat or inspect the internal display cable (LVDS/eDP) for any loose connections.
Does the laptop itself turn on, is there any fan noise, or does the keyboard turn on?
AlexS
Message 9 sur 9
1 338 Visites
Message 9 sur 9
1 338 Visites
))) I check all of this ) I mean that my laptop fix on 0,59 Amp use and no any post. Batt CMOS reset. I change Intel ME in my dump to new and clear. I mean that i have some skeels. I ask about work dump or original full image drom producent
8 RÉPONSES 8
