Medion erazer x7847. How to turn off the LED keyboard or change the color?
14 ANTWORTEN 14
dycpepsi
Nachricht 1 von 15
20.298 Aufrufe
Nachricht 1 von 15
20.298 Aufrufe
Hello friends, I bought this notebook without an operating system. I installed windows 10. The keyboard is always illuminated in blue. The key combination FN + / * - + should control the lighting of the keyboard but it does not work.
I believe that the correct drivers are not available on the medion website. The device manager recognizes it as PS / 2 Standard Keyboard.
Do you know how I can turn off the keyboard illumination and how to change the color?
Thank you.
dycpepsi
Nachricht 4 von 15
18.123 Aufrufe
Nachricht 4 von 15
18.123 Aufrufe
Hello, I have already solved it. I have downloaded the control center program and everything is working perfectly.
Thanks for everything.
A greeting.
Control Center -
14 ANTWORTEN 14
Bodgekin
Nachricht 2 von 15
18.132 Aufrufe
Nachricht 2 von 15
18.132 Aufrufe
Hi @dycpepsi
What is the MSN number of your notebook? I don't think the keyboard drivers are the problem, I think you need either an extra Hotkey driver / software, or some form of controll software.
Kind regards,
Bart
dycpepsi
Nachricht 3 von 15
18.128 Aufrufe
Nachricht 3 von 15
18.128 Aufrufe
Hello, thanks for replying. The Msn is:  30022356
I bought the notebook without an operating system. I do not have any software.
I downloaded all the drivers from the official medion website but I can not find anything for the keyboard.
I have all the drivers working correctly except the keyboard. It does not recognize  some combinations of keys FN + key among them those of the keyboard illumination.
Do you know any extra Hotkey driver / software, or some form of controll software for this notebook?
Thanks.
dycpepsi
Nachricht 4 von 15
18.124 Aufrufe
Nachricht 4 von 15
18.124 Aufrufe
A greeting.
Control Center -
Bodgekin
Nachricht 5 von 15
18.099 Aufrufe
Nachricht 5 von 15
18.099 Aufrufe
Hi @dycpepsi
Great to see you already solved it, and thanks for posting the solution, might help others as well!
Kind regards,
Bart
rebandrob
Nachricht 6 von 15
12.591 Aufrufe
Nachricht 6 von 15
12.591 Aufrufe
I have the same problem with my X7859 MSN:30025453 .... can you tell me how to repair it?. Thanks.
Roberto
Nachricht 7 von 15
12.556 Aufrufe
Nachricht 7 von 15
12.556 Aufrufe
Hi @rebandrob
Install the Control Center Software: http://www1.medion.de/downloads/download.pl?lang=de&filename=ctrx785x_6x_w10.exe&id=18409&type=treib...
Bye Fishtown
madmax99
Nachricht 8 von 15
8.339 Aufrufe
Nachricht 8 von 15
8.339 Aufrufe
Hi i have the same issue please helppp asap
Nachricht 9 von 15
8.330 Aufrufe
Nachricht 9 von 15
8.330 Aufrufe
Hello @madmax99 and welcome,
the solution is there! or what is your problem!
Which version do you have, X7959 or X7847.
Please enter your MSN number.
bye Fishtown
madmax99
Nachricht 10 von 15
8.176 Aufrufe
Nachricht 10 von 15
8.176 Aufrufe
my msn is 3002 9419
14 ANTWORTEN 14
