Medion erazer Crawler E30 MD62472 I need BIOS and EC
1 REPLY 1
soczi08
Message 1 of 2
Message 1 of 2
Hi,
I have purchased two Medion Erazer Crawler E30 laptops, both of which have the same issue: after some time, they either boot up with no display or don't respond to the power button at all. Resetting the CMOS battery helps. Sometimes it works after a few tries. Recently, I managed to update the BIOS on one of them, and it worked for a week, but then I had to reset the CMOS battery again. The second one stopped working yesterday. I flashed the same BIOS as for the other one, but now there's no response at all.
Could you please provide a clean BIOS and EC dump? I have the necessary programmers to flash the file. The file available on the forum doesn't fit my laptop, and the laptop won't start with it.
Motherboard model: 6-71-NP5K0-D02B
MSN 30034264
Apparently, this issue is repaired under warranty, but I bought the laptops second-hand, and it turns out someone had already taken them apart. I’ve heard that replacing "one" component resolves the issue, and the laptop works as it should.
1 REPLY 1
Olrajt69
Message 2 of 2
Message 2 of 2
Hello. Did you solve the problem? I have the same problem in my laptop and I no longer have a warranty. If you know anything about it, please write. Best regards
1 REPLY 1
