Medion e3222t only green led
2 REPLIES 2
lostprophet
Message 1 of 3
Message 1 of 3
Hey everyone! So a week ago I bought this laptop, and it worked fine, however when I tried using it today, I only get a black screen, with only the green LED on. It doesn't respond to any keys, and even the Medion logo doesn't show. Tried turning it off and on again, but nothing else happens. Any ideas?
Tags (1)
2 REPLIES 2
Bodgekin
Message 2 of 3
Message 2 of 3
Hi @lostprophet
Have you tried turning it off by keeping the powerbutton pressed for a long time, and then starting again? If it still does nothing after that I dont think there is any more you can try.
Kind regards,
Bart
lostprophet
Message 3 of 3
Message 3 of 3
i tried to keep the on/off button pressed, but it keeps turning off and on, if I do that.
I'm currently trying to fully drain the battery (it's draining so slow without the display on), and maybe it'll work again. If not, I'm go to send it back in warranty.
Forgot to mention, this whole thing happened, when I closed the top (to make the laptop go to sleep).
2 REPLIES 2
