Medion P7618 BIOS big problem
60 RÉPONSES 60
busa
Message 1 sur 61
157 172 Visites
Message 1 sur 61
157 172 Visites
hi, I have a problem with my Medion Akoya P7618 (MD98580), I downloaded and flashed the last bios from medion website (http://www.medion.com/de/service/_lightbox/treiber_details.php?did=10611), and now the wifi and external graphics card (GT540M) don't work anymore, how I can fix the problem or where I can download the orginal BIOS for the laptop?
Thanks.
Balises (3)
60 RÉPONSES 60
busa
Message 31 sur 61
94 983 Visites
Message 31 sur 61
94 983 Visites
@McB, you're right 🙂
McB
Message 32 sur 61
94 979 Visites
Message 32 sur 61
94 979 Visites
@busa ...
mostly 😉
unless @daddle extends my answers (within other threads)... a little 'bit' more - but anyway at best!
as i am quite lazy in writting/typing (programmers are lazy) 😉
don't forget to light the 4th candle tomtom & greetinx
Message 33 sur 61
94 887 Visites
Message 33 sur 61
94 887 Visites
@busa
Hi busa, it is great that it worked. I sent you a PN, please answer it asap.
Thanks, daddle
nnouk
Message 34 sur 61
94 526 Visites
Message 34 sur 61
94 526 Visites
I have the same problem. What the hell is MEDION doing placing such a wrong doing BIOS update on its website??
Could you please help me and send me the dumped previous BIOS version?
Message 35 sur 61
94 467 Visites
Message 35 sur 61
94 467 Visites
@nnouk Hallo und willkommen im Forum.
Saying Hello and Bye as well as addressing someone would be a nice gesture!
Aber egal, du hast eine PN.
McB
Message 36 sur 61
94 459 Visites
Message 36 sur 61
94 459 Visites
@nnouk
and please... 😉
greetinx
nnouk
Message 37 sur 61
94 434 Visites
Message 37 sur 61
94 434 Visites
only like 3 posts out of 36 include some Hallo so ask them first before teaching new ones please...
anyway the link helped so thx very much
Message 38 sur 61
94 414 Visites
Message 38 sur 61
94 414 Visites
@nnouk
Well I guess coming new into a forum or thread it is a good habit to say hello. Once you are in a dialog of course you
don't have to say greetings in every answering post again. That's the difference!
Message 39 sur 61
92 872 Visites
Message 39 sur 61
92 872 Visites
Hallo @daddle.
Wir haben das BIOS Update erstmal entfernt um nicht noch mehr Fälle zu produzieren, in denen sich die Grafikkarte und das WLAN nicht mehr installieren lassen.
Das Gerät ist von 2011 und weder das ursprüngliche BIOS noch das jetzt entfernte wurde im Hinblick auf Windows 10 programmiert. Aufgrund des Alters wird es für dieses Gerät kein aktuelleres BIOS mehr geben. Daher wird das Rückspielen der alten BIOS Version (für die Leute, die schon geflasht haben) der einzige Workaround bleiben.
busa
Message 40 sur 61
92 861 Visites
Message 40 sur 61
92 861 Visites
@Andi
I installed windows 10 after flash back to 009, and it work without any problem, windows install all required drivers via win update.
60 RÉPONSES 60
