Medion P7618 BIOS big problem
60 ANTWOORDEN 60
busa
Bericht 1 van 61
155.990 Weergaven
Bericht 1 van 61
155.990 Weergaven
hi, I have a problem with my Medion Akoya P7618 (MD98580), I downloaded and flashed the last bios from medion website (http://www.medion.com/de/service/_lightbox/treiber_details.php?did=10611), and now the wifi and external graphics card (GT540M) don't work anymore, how I can fix the problem or where I can download the orginal BIOS for the laptop?
Thanks.
Tags (3)
60 ANTWOORDEN 60
busa
Bericht 31 van 61
94.820 Weergaven
Bericht 31 van 61
94.820 Weergaven
@McB, you're right 🙂
McB
Bericht 32 van 61
94.816 Weergaven
Bericht 32 van 61
94.816 Weergaven
@busa ...
mostly 😉
unless @daddle extends my answers (within other threads)... a little 'bit' more - but anyway at best!
as i am quite lazy in writting/typing (programmers are lazy) 😉
don't forget to light the 4th candle tomtom & greetinx
Bericht 33 van 61
94.724 Weergaven
Bericht 33 van 61
94.724 Weergaven
@busa
Hi busa, it is great that it worked. I sent you a PN, please answer it asap.
Thanks, daddle
nnouk
Bericht 34 van 61
94.363 Weergaven
Bericht 34 van 61
94.363 Weergaven
I have the same problem. What the hell is MEDION doing placing such a wrong doing BIOS update on its website??
Could you please help me and send me the dumped previous BIOS version?
Bericht 35 van 61
94.304 Weergaven
Bericht 35 van 61
94.304 Weergaven
@nnouk Hallo und willkommen im Forum.
Saying Hello and Bye as well as addressing someone would be a nice gesture!
Aber egal, du hast eine PN.
McB
Bericht 36 van 61
94.296 Weergaven
Bericht 36 van 61
94.296 Weergaven
@nnouk
and please... 😉
greetinx
nnouk
Bericht 37 van 61
94.271 Weergaven
Bericht 37 van 61
94.271 Weergaven
only like 3 posts out of 36 include some Hallo so ask them first before teaching new ones please...
anyway the link helped so thx very much
Bericht 38 van 61
94.251 Weergaven
Bericht 38 van 61
94.251 Weergaven
@nnouk
Well I guess coming new into a forum or thread it is a good habit to say hello. Once you are in a dialog of course you
don't have to say greetings in every answering post again. That's the difference!
Bericht 39 van 61
92.709 Weergaven
Bericht 39 van 61
92.709 Weergaven
Hallo @daddle.
Wir haben das BIOS Update erstmal entfernt um nicht noch mehr Fälle zu produzieren, in denen sich die Grafikkarte und das WLAN nicht mehr installieren lassen.
Das Gerät ist von 2011 und weder das ursprüngliche BIOS noch das jetzt entfernte wurde im Hinblick auf Windows 10 programmiert. Aufgrund des Alters wird es für dieses Gerät kein aktuelleres BIOS mehr geben. Daher wird das Rückspielen der alten BIOS Version (für die Leute, die schon geflasht haben) der einzige Workaround bleiben.
busa
Bericht 40 van 61
92.698 Weergaven
Bericht 40 van 61
92.698 Weergaven
@Andi
I installed windows 10 after flash back to 009, and it work without any problem, windows install all required drivers via win update.
60 ANTWOORDEN 60
