Medion Erazer Beast X40 RTX4080&i9 Bios&Maintance
3 ANTWORTEN 3
ajmRa1n
Nachricht 1 von 4
1.018 Aufrufe
Nachricht 1 von 4
1.018 Aufrufe
Hello,
1) So i'm experiencing this issue when i play demanding games that laptop needs to run fans on a full speed just so it doesn't blue screen. And from what i've found it's apparently due to faulty default Bios. So if i could get updated Bios and little tutorial on how to do that that would be very helpful.
2) From time to time fans have this weird sound, like one or both of the bearings is going out which is odd on a 2yr old laptop. Would post a video with sound but can't.
If there's something needed let me know.
Thanks
Tags (3)
3 ANTWORTEN 3
Nachricht 2 von 4
1.006 Aufrufe
Nachricht 2 von 4
1.006 Aufrufe
@ajmRa1n
You hould state the MSN number of your Beast X40 to identify xour mainboard exactly.
It is to be found on a sticker on the backside.
Cheers, daddle
ajmRa1n
Nachricht 3 von 4
986 Aufrufe
Nachricht 3 von 4
986 Aufrufe
So MSN is 30035237.
ajmRa1n
Nachricht 4 von 4
985 Aufrufe
Nachricht 4 von 4
985 Aufrufe
Hello,
so it's not always constant fullspeed. On a normal use like streaming netflix & amazon video it's silent. You can hear fans are on, but without any excess bearing sounds, those come on when i play game as mentioned.  And when i do stop playing and go back to streaming any media that sound still stays but it's clear to say it increases and decreases with speed of the fans. Only time when i don't hear it is when fans are on max. Which is understandable as they have high RPM. And unfortunately i don't think my laptop is under warranty as it's been once that i had to send it to Medion for a repair as screen on my first laptop was faulty and i've recevied new laptop as the faulty according to Medion was unrepairable. I'll have a look in Medion Diagnostics app and log in there to see if this one is under warranty but i'm afraid it won't be
3 ANTWORTEN 3
