Medion Akoya P2212T SSD upgrade
7 REPLIES 7
pcpartpicker
Message 1 of 8
Message 1 of 8
Hi guys.
I own this laptop where performance of it's system drivewith Windows installation is simply terrible.
I ran CrystalDisk info and got info that system disk is some HC8GE 64GB with terrible performance.
Since I have spare 250 GB SSD may I install it to this laptop and boot from that drive,and somehow either uninstall this 64GB or not use ir at all?
I'd install Windows to this 250GB drive.
Is it possible to install Windows on that drive and bypass OEM one (this 64GB crap)?
1 ACCEPTED SOLUTION
EastClintwood
Message 6 of 8
Message 6 of 8
Hello @pcpartpicker,
Since the SSD you are referring to is an EMCC flash memory, it is not expandable (expandable with microSD/SDHC/SDXC memory cards).
I hope I was able to help you with this.
Greetings,
EastClintwood
7 REPLIES 7
EastClintwood
Message 2 of 8
Message 2 of 8
Hello @pcpartpicker, and welcome to the community.
Create a Windows installation medium with the Media Creation Tool on a USB stick or DVD.
Softwaredownload (microsoft.com)
Then install Windows on your new ssd.
With kind regards,
EastClintwood
pcpartpicker
Message 3 of 8
Message 3 of 8
But SSD is not replaceble on this model,correct?
It's in the tablet.
EastClintwood
Message 4 of 8
Message 4 of 8
please send me your MSN number so we can have a look at your exact spec.
Best regards,
EastClintwood
pcpartpicker
Message 5 of 8
Message 5 of 8
MSN number: 30016963
EastClintwood
Message 6 of 8
Message 6 of 8
Greetings,
EastClintwood
pcpartpicker
Message 7 of 8
Message 7 of 8
But can I install Windows onto HDD drive on the base of the laptop?
Message 8 of 8
Message 8 of 8
Hello @pcpartpicker
that is not possible, then your tablet would be alone without an operating system.
bye Fishtown
7 REPLIES 7
