Medion Akoya E6215 Help Request
1 ANTWORT 1
nunomgnunes
Visitor
Nachricht 1 von 2
1.823 Aufrufe
Nachricht 1 von 2
1.823 Aufrufe
Good evening, I bought a used medion akoya e6215 (MD97689) with MSN: 30011961 and wanted to know if there is any way to put wifi without active on the linux system boot without having to be using the FN + F2 keys all the time and since on windows 10 i installed a hotkey and it works well and also wanted to know if i can change the cpu that comes with the pc (Pentium P6100 and if i can change an i7-640M) and there is a bios updtae since the site does not find none, thank you very much
1 ANTWORT 1
Gehringer
Retired
Nachricht 2 von 2
1.781 Aufrufe
Nachricht 2 von 2
1.781 Aufrufe
Hi @nunomgnunes ,
unfortunately we can only support products on its original condition but maybe the community will be able to help you!
Are there any Linux experts out there?
Regards,
Gehringer
1 ANTWORT 1
