Intel 9462 wireless adaptor has completely disappeared on my Medion P6645 Laptop
1 REPLY 1
Thomassutherlan
Message 1 of 2
Message 1 of 2
Hello all,
Just joined today as I am having a nightmare. Any advice is at all appreciated.
Today my wireless adaptor completely disappeared. I've been having a lot of trouble with it disconnecting then re-connecting right after start up for a long time.
Today I loaded it up and there is no option to connect to a wi-fi adapter.
I have:
Reset the machine.
Done a network reset.
Used troubleshooting.
Uninstalled the driver.
Reset my system BIOS to factory settings.
Completely re-installed windows.
Downloaded the Intel drivers onto a USB stick and re-installed them.
I have a Medion PP645-MD61361.
The Intel adaptor no longer shows in my device manager, it's completely gone. However a "Network Controller" has showed up in Other Devices but I can't update it with the intel drivers or the internet as I don't have access to it on that machine.
Can anybody shed some light as to what I might have missed please?
Thank you,
Thomas
1 ACCEPTED SOLUTION
Message 2 of 2
Message 2 of 2
@Thomassutherlan
That's bad luck. I guess your wi-fi adaptor is defective. Just get a replacement.
Cheers, daddle
1 REPLY 1
Message 2 of 2
Message 2 of 2
@Thomassutherlan
Cheers, daddle
1 REPLY 1
