Erazer X7851
13 RÉPONSES 13
WhateverOverIt
Message 1 sur 14
8 932 Visites
Message 1 sur 14
8 932 Visites
Erazer X7851
I appear to have suddenly lost the control centre that allows me to change the keyboard backlight and it has reverted to blue.
It's not the first time this has happened and on previous occassions I've managed to fix it after spending way too long googling and trying everything. This time though I cannot figure it out.
I downloaded the correct control centre (I think) but still nothing works and the control centre doesn't even show as installed.
I'm seriously pulling my hair out here, can someone please help?
Thank you
13 RÉPONSES 13
WhateverOverIt
Message 11 sur 14
2 646 Visites
Message 11 sur 14
2 646 Visites
Thank you for hanging on in there with me.
So yes, I extracted all and used setup from those files.
I will send screenshots. I just did an uninstall and reinstalled - still nothing. I'm not sure where to find installed programs but control centre is given as an option to uninstall if that helps.
I'm utterly lost as to what is wrong.
WhateverOverIt
Message 12 sur 14
2 627 Visites
Message 12 sur 14
2 627 Visites
Hi Fishtown
Just wondering if you could offer any further thoughts or advice?
Thank you
Message 13 sur 14
2 600 Visites
Message 13 sur 14
2 600 Visites
Hello @WhateverOverIt
Unfortunately, I don't know why the control center can't be switched on either.
In the worst case, you should back up your personal data and restore drive c : to the delivery state and reinstall the operating system with the drivers and CC from drive d : without having an internet connection. it could be that a windows update is causing the problems and that's why the CC doesn't show up.
bye Fishtown
ice-JAck
Message 14 sur 14
1 619 Visites
Message 14 sur 14
1 619 Visites
Hi,
I have had the same issue for years, and I still do. Hopefully, with the right support, it will be fixed.
13 RÉPONSES 13
