E15407 (MSN 30030605) Security updates
2 REPLIES 2
rebit
Message 1 of 3
Message 1 of 3
uCodeuCodeCSMECSME
Any idea if I can get updated UEFI for uCode 0xA6 (Jun '21) or fix for Intel SA-00459?
Tags (1)
1 ACCEPTED SOLUTION
rebit
Message 3 of 3
Message 3 of 3
@Gehringer thanks for your reply but the system firmware is not normally delivered via Windows Update.
I have all devices up to date via Device Manager or IDSA (Intel Driver and Software Assistant)
I have also managed to update the Intel Converged Security and Management Engine via a third-party website.
2 REPLIES 2
Gehringer
Retired
Message 2 of 3
Message 2 of 3
Hi @rebit ,
have you tried to update the firmware and the device drivers using the device manager tool?
Regards,
Gehringer
rebit
Message 3 of 3
Message 3 of 3
2 REPLIES 2
