12.08.2018 16:38 - modifié 12.08.2018 17:43
le 13.08.2018 10:02
le 13.08.2018 10:02
Hi @vikado and welcome to the MEDION Community,
E3215 & E3216 describe one and the same model series. They differ just in terms of the size of SSD, HDD & RAM. The used display panels are identical.
Cheers
le 13.08.2018 10:02
le 13.08.2018 10:02
Cheers
le 14.11.2018 16:34
le 14.11.2018 16:34
This is not correct, it's exactly the opposite, RAM and SSD are the same, only the Screen is different between both models, the screen of the 3215 is a bit brighter, that's all as far as I know.
Subject | Author | Posted | |
16.12.2024 18:26 | |||
12.08.2018 16:30 | |||
14.08.2020 11:49 | |||
06.12.2024 18:10 |
