23.07.2021 19:57
23.07.2021 19:57
Madion akoya msn30020524. When i first acquired this laptop it ran great. But now the cooling fan is running at max at start-up and all the time i use it. Also since this has happened the laptop is not as quick as it used to be. I have just had a fresh windows installation to see if that would cure it, but has not helped. As of now there is no programs running but fan still running at max. Any suggestions much appreciated.
26.07.2021 08:20
26.07.2021 08:20
Hi @Mazakin,
you've mentioned you have already performed a clean Windows installation so I assume you've update Windows (including optional updates) and drivers to their latest versions, correct?
If so, you can try to install a monitoring software to check units' temperature to see it is a fan issue or an overheating issue.
It would also help to download and install the Medion Service app available here to look for faults.
Regards,
Gehringer
01.08.2021 13:32
01.08.2021 13:32
Hi, Thanks for your help, I ran the diagnostics as instructed. Did all updates and restarted, Got as far as checking video adapter and froze and would not go any further. Did this a second time and froze again on memory test. So the fan is still running at max and programs running slow. This laptop has not been used for awhile because of this problem.
Quite awhile ago when this problem first started i was messing and i put the memory ram in the second empty slot and this cured the problem ?????. This ran perfectly for about three months and then it started again and i have tried a new ram but still no good. What you think?.
02.08.2021 09:49
15.09.2021 09:04
15.09.2021 09:04
Hi, We are still working on the unit. Fitted new ssd drive, Updates for nvidia which were missing, new rams, bios updates and do you know, it is still a pile of shit.
Was hoping to play World of warcraft as a spare but it will not even load the game and if it do's it comes up 3d accelerator missing.
