29.01.2023 13:10 - bewerkt 29.01.2023 13:11
Can I upgrade the CPU in the X7853-MD60696 MSN 30023007?
I need software that specifies minimum 6 cores and I only have 4.
ftm can I upgrade ram from 16gb to 32mb?
I love this machine but need a bit more oompf and its only 3 years old.
Pat
op 29.01.2023 18:36
op 29.01.2023 18:36
Hello @patbell101 and welcome
this can't work. The CPU hardware (Intel Core i7-7820HK 2.90GHz ) only has 4 cores.
unfortunately you can't exchange the cpu because it is soldered (socket bga)
You have 2 x 8192 MB DDR4 SO-DIMM (PC4-19200/2400 MHz)
(2/4 occupied; 64 GB max.)
Bye Fishtown
op 29.01.2023 20:45
op 29.01.2023 20:45
Hi @patbell101
if you want it faster: you have a 2TB SATA HDD and a 512GB M.2 SSD SATA.
you could swap both.
HDD against SSD 2.5" (you can do that, but you don't have to)
and the M.2 SSD SATA against an M.2 SSD PCIe.(this is the better solution/ option)
The computer is a Barebone Clevo P670HS-GM / load the service manual P67XHS_SM(2010202)
bye Fishtown
