CPU Upgrade?
2 ANTWOORDEN 2
patbell101
Bericht 1 van 3
2.525 Weergaven
Bericht 1 van 3
2.525 Weergaven
CPU Upgrade?
Can I upgrade the CPU in the X7853-MD60696 MSN 30023007?
I need software that specifies minimum 6 cores and I only have 4.
ftm can I upgrade ram from 16gb to 32mb?
 I love this machine but need a bit more oompf and its only 3 years old.
Pat
2 ANTWOORDEN 2
Bericht 2 van 3
2.519 Weergaven
Bericht 2 van 3
2.519 Weergaven
Hello @patbell101  and welcome
this can't work. The CPU hardware (Intel Core i7-7820HK 2.90GHz ) only has 4 cores.
unfortunately you can't exchange the cpu because it is soldered (socket bga)
You have 2 x 8192 MB DDR4 SO-DIMM (PC4-19200/2400 MHz)
(2/4 occupied; 64 GB max.)
Bye Fishtown
Bericht 3 van 3
2.514 Weergaven
Bericht 3 van 3
2.514 Weergaven
Hi @patbell101
if you want it faster: you have a 2TB SATA HDD and a 512GB M.2 SSD SATA.
you could swap both.
HDD against SSD 2.5" (you can do that, but you don't have to)
and the M.2 SSD SATA against an M.2 SSD PCIe.(this is the better solution/ option)
The computer is a Barebone Clevo P670HS-GM / load the service manual P67XHS_SM(2010202)
https://my.hidrive.com/share/yze8mg-wf8#$/CLEVO%20Service%20Manual%20Books/P_Series/P6_Series/P6xxHx...
bye Fishtown
2 ANTWOORDEN 2
