Broken laptop adapter
4 ANTWORTEN 4
Peter14
Nachricht 1 von 5
5.852 Aufrufe
Nachricht 1 von 5
5.852 Aufrufe
Hello I am from Slovakia and i have bought Laptop Medion Erazer X7827 few years ago.
Now my charging adapter is broken and i cant find new one for my laptop.Is adapter from Medion Erazer X7841 same like for my Laptop ?
4 ANTWORTEN 4
Nachricht 2 von 5
5.839 Aufrufe
Nachricht 2 von 5
5.839 Aufrufe
@Peter14
Hallo Peter, mostly any laptop-charger with minimum 90 W should do the job.
I guess the technical details are printed onto you original Charger; propably sec. 19 V with  4.4 amp. rating;
 also some Erazer have an 120 W supply, 19V and  6.3 amp. Any notebook charger in this range should work, just take care the plug has the same inner and outer diameter. But with universal chargers a range of  adapters  for different types are supplied.
regards, daddle
Peter14
Nachricht 3 von 5
5.834 Aufrufe
Nachricht 3 von 5
5.834 Aufrufe
Hello ty for your answer but problem is that my adapter is 180W 19.5V and 9.2A i tried 120w universal adapter with right connector laptop was working but adapter wasnt charging him and when i started some download and more power needed activity it just shuted down. I found 120W maximum for universal adapters so propably i am going to need original one ...
Nachricht 4 von 5
5.825 Aufrufe
Nachricht 4 von 5
5.825 Aufrufe
@Peter14
Aha, then I am sorry. I did not expect the Erazer not to work with a 120 W charger; but yoh could have mentioned the needed specificatios in your first post.
With the charger from the other Erazer you can ask one of the mods here, maybe @RS13 can help you and tell us if the charger from the X7481 delivers the necessary amount of currence.
Regards, daddle
RS13
Master NL
Nachricht 5 von 5
5.819 Aufrufe
Nachricht 5 von 5
5.819 Aufrufe
Hi @Peter14@daddle
Yes, the X7841 charger also delivers 19,5V and 9,2A, so as far as I can tell, they should be interchangeable.
Kind regards,
Paul
4 ANTWORTEN 4
