Battery 255 %
21 ANTWOORDEN 21
BGR
Bericht 1 van 22
6.537 Weergaven
Bericht 1 van 22
6.537 Weergaven
Battery 255 %
Laptop P6661 does not turn on with battery. The battery icon on taskbar shows  - 255 %available. Plugged in. If the charger is plugged off, the laptop shuts down immediately. Purchase a 2 new generic batteries - no success, The red light of battery on laptop panel is flashing when charger is connected.  Web wide ways to solve this issue was done. Nothing works. Somebody could help? Thanks in advance,
21 ANTWOORDEN 21
Bericht 2 van 22
2.961 Weergaven
Bericht 2 van 22
2.961 Weergaven
@BGR
You should at least state the MSN number of your Laptop.
Second:  255% charging status I have never heard  of. It indicates  the charging circuit on the board seems to be defect (just a guess).
The fact that with two batteries replaced the same  occurs.
What  do you mean t with:
Purchase a 2 new generic batteries - no success  "  so no orig. batteries from Medion?
Did you check the amperage the Charger delivers? It could be defective.
BGR
Bericht 3 van 22
2.958 Weergaven
Bericht 3 van 22
2.958 Weergaven
Hi, thanks for reply. The laptop's MSN 30020565. Sure I bought non original Medion batteries. The charger is OK, another laptop charges well.
Bericht 4 van 22
2.951 Weergaven
Bericht 4 van 22
2.951 Weergaven
@BGR
Sure the non original batteries have same spec as the original ones?
So the only thing you could do ist replacing the power board:
https://www.medion.com/medionserviceshop/de/p/gehause-medion-erazer-p6661-md-99953--be-30020565
Scroll down, then you scroll down, then you see the powerboard entry:
--> https://www.medion.com/medionserviceshop/de/p/div-boards-power-switch-board-40057127
BGR
Bericht 5 van 22
2.943 Weergaven
Bericht 5 van 22
2.943 Weergaven
Thanks for links.
Yeah, the specifications of batteries are the same like original one.
It is a link: https://www.ebay.de/itm/335457195062?_skw=medion+p6661+akku&itmmeta=01JHX0GH1VNWGKKKNNAYEQYBQ9&hash=...
Bericht 6 van 22
2.942 Weergaven
Bericht 6 van 22
2.942 Weergaven
hello @BGR and welcome
Please check the volts of the old battery with your current one.
The A41-D15 44Kh battery was delivered/operated with 15.2 volts or 11.4 volts in some models
bye Fishtown
BGR
Bericht 7 van 22
2.937 Weergaven
Bericht 7 van 22
2.937 Weergaven
The laptop runs well when charger is plugged in. Do you really think the problem could be on power board?
BGR
Bericht 8 van 22
2.936 Weergaven
Bericht 8 van 22
2.936 Weergaven
Batteries voltage 15,2 V.
BGR
Bericht 9 van 22
2.934 Weergaven
Bericht 9 van 22
2.934 Weergaven
BGR
Bericht 10 van 22
2.923 Weergaven
Bericht 10 van 22
2.923 Weergaven
I guess the problem is on motherboard power controller chip.
21 ANTWOORDEN 21
