23.10.2023 19:26
23.10.2023 19:26
Hey, so I want to add a second SSD to my notebook. I do not have any relevant experience in this matters but as far as I can tell I need a 2,5 inch SSD with a FFC to SAT adapter is that correct? And is this even possible or will this cause any problems, normally there would be an extra cable for excatly that but I do not think thats the case with this model.
16.11.2023 09:23
16.11.2023 09:23
Hi,
This cable should be the right one:
https://www.medion.com/medionserviceshop/en/p/cable-internal-cable-ribbon-cable-hdd-40069483
MSN: 40069483
Worked for me.
03.01.2024 07:26
03.01.2024 07:26
Hi @bebibe789 ,
could you please give us an update,if the solution worked out vor you?
Cheers
