Akoya MD61214 mousepad and W11
1 REPLY 1
bacterio
Message 1 of 2
Message 1 of 2
Hello. I updated W11 on my Akoya MD61214 and the mousepad doesn´t work anymore. Can´t find the right driver in Medion page... Anyone can help with this?
Thanks in advance
1 REPLY 1
daldasa
Message 2 of 2
Message 2 of 2
Thanks in advance
had the same issue after updating to Windows 11 on my Akoya MD61214. To fix it, try checking Device Manager for the touchpad driver and updating it, or use Windows Update to find a compatible driver. If that doesn’t work, you can look for the touchpad driver on the manufacturer's site, or try rolling back to a previous driver if available. If nothing works, uninstalling the driver and restarting the laptop may prompt Windows to reinstall a generic driver automatically.
1 REPLY 1
