le 04.07.2023 16:51
le 04.07.2023 16:51
Medion Akoya E7214 running Windows 7.
When I put the compujter to sleep, All the normal events take place up to the point where the computer should turn itself off - and then nothing happens. Eventually I press the start/stop button and it turns off.
And when I turn it on again it resumes exactly as if it had actually gone to sleep.
This is irritating especially as if I turn it off too soon (I need to wait maybe a minute after it looks like it has stopped) it does not resume
Restart works fine: Turns itself off then back on again
So how do I make sleep turn off automatically?
le 31.07.2023 12:25
le 31.07.2023 12:25
Hello there, @Rincewind
It sounds like some of your settings may be preventing the shut down. Please head into your control panel and then select:
Power options> Change plan settings (make sure to click the one corresponding with your preferred plan)> Change advanced power settings
From here I would recommend checking your Multimedia settings and Sleep settings as these could both be causing the issue you have described.
- Jacob P
le 04.08.2023 22:20
le 04.08.2023 22:20
If only . . .
Advanced settings
Sleep is allowed
Hybrid sleep is allowed
Wake timers are disabled
Lid close action - Sleep (does not switch off). If I close the lid it sleeps but does not turn off
Sleep button action - Sleep but it does nothing
If I set sleep on battery after 1 minute and leave it,, it sleeps but does not turn off. (I turn it off and back on and it resumes just fine)
If I try start->shutdown it shuts down but wont turn off
