Akoya E4251 boot from m.2
18 ANTWOORDEN 18
Acelsp
Bericht 1 van 19
20.504 Weergaven
Bericht 1 van 19
20.504 Weergaven
Hello,
I have a Medion Akoya E4251 and it has a m.2 slot. I am thinking about installing a new m.2 drive and my question is if windows can boot from m.2 drive (faster), instead of onboard drive (slower).
Thanks.
18 ANTWOORDEN 18
Bodgekin
Bericht 2 van 19
12.433 Weergaven
Bericht 2 van 19
12.433 Weergaven
Hi @Acelsp ,
Which E4251 do you have exactly? And are you sure that the harddrive you have currently is on the motherboard? The models I could find all seem to already have an M.2 SSD, and no integrated harddrive.
Kind regards,
Bart
Acelsp
Bericht 3 van 19
12.428 Weergaven
Bericht 3 van 19
12.428 Weergaven
It is MSN 30025555 model. It has an integrated 64GB eMMC on board
Bodgekin
Bericht 4 van 19
12.365 Weergaven
Bericht 4 van 19
12.365 Weergaven
Hi @Acelsp ,
Then I don't see why it would not be possible to boot from the M.2 SSD, you should be able to install Windows on it using the Media creation tool.
Kind regards,
Bart
Acelsp
Bericht 5 van 19
12.357 Weergaven
Bericht 5 van 19
12.357 Weergaven
In that case, I think I would need a windows key to use that tool. And in my case windows is already installed in eMMC drive, but I don’t have the key to reinstall it
jjrodri07
Bericht 6 van 19
12.329 Weergaven
Bericht 6 van 19
12.329 Weergaven
The windows key is usually in the system BIOS. So you should not ask it and windows will install perfectly.
When it's time to ask for the windows key, it will read it automatically from the BIOS and will not ask you.
This is usually done normally. And it should be like that in Medion Akoya E4251.
I'm going to do like you.
By the way the SSD that you are going to put is NVMe?
Acelsp
Bericht 7 van 19
12.327 Weergaven
Bericht 7 van 19
12.327 Weergaven
I was thinking in a sata m.2. I don’t think nvme is supported
jjrodri07
Bericht 8 van 19
12.325 Weergaven
Bericht 8 van 19
12.325 Weergaven
I have an NVME to prove it.
Out of curiosity, throughout the day, when I have a gap. I'm going to see if the Akoya E4251 can recognize it.
I'll tell you
Acelsp
Bericht 9 van 19
12.320 Weergaven
Bericht 9 van 19
12.320 Weergaven
Great!! Waiting for your results... Thanks!! 😊
TPFLegionaire
Retired
Bericht 10 van 19
12.317 Weergaven
Bericht 10 van 19
12.317 Weergaven
@jjrodri07
We really appreciate your help, looking forward to your findings
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
18 ANTWOORDEN 18
