Akoya E4271 m.2 supported?
2 REPLIES 2
rmb
Message 1 of 3
Message 1 of 3
Hello.
I have a Medion Akoya E4271 and it has a m.2 slot. The manual does not indicate which SSD hard drives supports that slot: PCIe, NVMe or SATA III.
Can anyone tell me what type of disk this model supports?
Thanks.
1 ACCEPTED SOLUTION
TPFLegionaire
Retired
Message 2 of 3
Message 2 of 3
Hi @rmb
Here are the interface specs.:
SATA Interface: SATA Revision 3.2
* SATA 1.5Gbps, 3Gbps, and 6Gbps interface
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
2 REPLIES 2
TPFLegionaire
Retired
Message 2 of 3
Message 2 of 3
Hi @rmb
Cheers!
TPFLegionaire
rmb
Message 3 of 3
Message 3 of 3
Great! Thanks a lot.
2 REPLIES 2
