am 14.08.2020 11:49
am 14.08.2020 11:49
Hello
WHere I can find drivers for networking/lan and wifi for medion akoya e3216 which is compatibility with windows 10.
am 16.09.2020 16:59
am 16.09.2020 16:59
I did, it worked with wlan but other drivers windows update can not find!
17.09.2020 09:53 - bearbeitet 17.09.2020 09:55
Hi @donky,
if W10 automatic update tool can't find any driver update it is probably because your device already has the most update driver installed.
Also, the driver manufacturer may have the last driver version on its website, just like Intel had for the WLAN adapter you've mentioned
Regards,
Gehringer
