I have downloaded my drivers and put them onto a drive but what do I do? (WiFi problem)
1 ANTWORT 1
Rkjr
Nachricht 1 von 2
446 Aufrufe
Nachricht 1 von 2
446 Aufrufe
Idk what to do next, it doesn't have an exe file to work with so I'm not sure
1 ANTWORT 1
RAZZ
Nachricht 2 von 2
404 Aufrufe
Nachricht 2 von 2
404 Aufrufe
Hi @Rkjr
Firstly what unit do you have, could you let us know the MSN?
Are you not able to connect a ethernet cable to the unit and update drivers that way?
What sort of drive have you downloaded drivers onto and from where?
What is the initial fault? no WIFI?
Thanks
1 ANTWORT 1
