How to add 3.5" HDD to my ERAZER ENGINEER X30?
7 REPLIES 7
CluelessGamer
Message 1 of 8
Message 1 of 8
Hi there,
I recently purchased an Erazer Engineer X30 and would like to install a 3.5" HDD (Toshiba HDWE140). I've already located the HDD bay, but am struggling to connect the right cables.
Can anyone please confirm which cable and ports I need to use? If I'm correct I need:
  • SATA power cable (bigger port on my HDD) which I believe is already connected to the PSU?see photo below
• SATA data cable. Here I'm not sure which cable to use. Should I use the middle L-port of my HDD for this or the right one with the two pins? Is the SATA data cable either one in the photo below? Or do I need a different one which is not included?
If it's another SATA data cable, where should I connect it to my PC?
Sorry for my ignorance, help would be appreciated!
Tags (3)
2 ACCEPTED SOLUTIONS
Message 4 of 8
Message 4 of 8
@CluelessGamer
You first should state your MSN number.  it can be located on a sticker underneath  the case, or on the back. It also should stand  on the box, or on a guarantee card.
Your picture I can not see yet; it will be only be seen  tomorrow after authorization.
I guess your mainboard is most probably a GIGABYTE™ B760M GAMING X AX 1.2, depending on the MSN number.
On the picture below you can see right below near the right corner two  SATA slots marked SATA3,  4 and 5, with a L-formed internal shape or partition.
L-
GIGABYTE™ B760M GAMING X AX 1.2GIGABYTE™ B760M GAMING X AX 1.2
Cheers, daddle
Message 7 of 8
Message 7 of 8
@CluelessGamer
Umgekehrt ginge es besser. Erkennst Du im abgebildetem Mainboard gleiche Strukturen bei deinem Board? In deinen Bildausschnitten lässt sich schwer erkennen, ob es gleich ist.
Sieht dein Rechner und die Ausstattung auf der PDF gleich deinem Rechner aus? Entscheidend ist das Gehäuse und die Angaben zum Mainboard.
https://media.medion.com/prod/medion/de_DE/0779/0789/0724/10025637.pdf
Ob nun 16 GB RAM angegeben sind oder 32 GB, oder eine etwas kleinere oder größere Platte spielt keine Rolle.
Kann im Moment nicht auf die kleine Datenbank zugreifen.
In English translation:
Things would be better the other way around. Do you recognize the same structures on your board in the mainboard shown? It's hard to tell from your cropped images whether it's the same.
Does your computer and the equipment on the PDF look the same as your computer? The decisive factors are the housing and the information about the mainboard.
It doesn't matter whether 16 GB of RAM is specified or 32 GB, or a slightly smaller or larger drive.
I can not  access the small database at the moment, to check exactly.
Gruß, daddle
7 REPLIES 7
Message 2 of 8
Message 2 of 8
@CluelessGamer
You have to buy a separate SATA cable, connect it to the contact strip     next to the power connexion. For the mainboard side the SATA plug looks alike, look on the google search result. Such things you  can google by yourselfself., to find a suitable trading shop.
--> https://www.google.com/search?q=SATA+cable&oq=SATA+cable&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCTYxMzhqMGo...
Here is a ready cable --> https://www.ebay.de/itm/134897847229?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SI...
Cheers, daddle
CluelessGamer
Message 3 of 8
Message 3 of 8
Hi @daddle. Thanks for the quick response and clarification. Could you please specify where exactly I can find the SATA port on the morherboard? I couldn't locate it myself. Some photos of my pc below as referenc
I've ordered a SATA cable, now I need to know where to connect it to my PC. I did try to google it, but nowhere to be found for this specific PC model. Thanks again!
Message 4 of 8
Message 4 of 8
@CluelessGamer
L-
Cheers, daddle
CluelessGamer
Message 5 of 8
Message 5 of 8
Hi @daddle . The MSN: 10025557. It a X30 Model: IW327E. Hope that helps.
CluelessGamer
Message 6 of 8
Message 6 of 8
@daddle Wanted to check in if you are able to see my photos above now that I'm authenticated? Is the MSN I shared the one you suspected?
Message 7 of 8
Message 7 of 8
@CluelessGamer
Gruß, daddle
CluelessGamer
Message 8 of 8
Message 8 of 8
Hi @daddle . Wanted to give a quick update: in the meantime I found 2 SATA ports at the bottom. The GPU was covering them. Was able to connect my HDD to a data and power cable, so cheers for that!
7 REPLIES 7
