45227members
1647online
156017posts
Why do I have no radio signal?
To ensure that the stations are stored correctly and not misaligned, perform a channel scan again as described in the user manual.
Radio reception depends on the location of the radio inside the building (for example cellar, condition of the walls), local conditions (for example in a valley or near the ground in cities with tall buildings) and the position of the wire antenna. To find the ideal reception place set a frequency of a known radio station, change the position of the wire antenna and the radios (for example close to a window) until you receive the station.
Review Date: 2021-10-28
