How do I connect my tablet or smartphone to a PC?
If the computer recognizes the Android smartphone or tablet but does not display any folders, this is usually due to the Media Transfer Protocol (MTP) not being activated.
The MTP connection is activated as follows:
Once MTP has been activated, Android usually only asks whether MTP should be allowed when the device is reconnected. If no folders are displayed despite MTP being activated, the cable should be reconnected or the device switched off and on again.
⚠️Note⚠️ Please note that the dialogues may differ slightly depending on the Android version installed.
The USB cable used must be suitable for data transfer. There are also USB cables, often supplied with stand-alone chargers, whose pin assignment is only suitable for charging.
ChangeLog:
Article in other languages:
Review Date: 2025-04-09
