If you see the 0x800F0922 error message, it could mean that your computer isn't connecting to the Microsoft update servers, or there might not be enough available space in the System Reserved partition. How can you fix this problem?
You can try to resolve this problem by making sure your device isn't disconnected from the internet.
Error 0x800F0922 may appear if you're using a VPN connection. If this is the case, disconnecting the device will help to update your system.
It rarely happens, but sometimes applications, such as security software, may store data in the System Reserved partition which may prevent your device from updating.
You can use third-party tools to resize the partition and make it larger (at least 500MB).
Review Date: 2021-06-18
