46059members
4453online
158101posts
The CPUs are soldered (BGA socket) and can therefore not be exchanged.
There are 2 memory slots on the mainboard each with 32 GB RAM. The maximum capacity is therefore 64 GB.
| Module: | 260-Pin SO-DIMM |
| Type: | SDRAM DDR4 |
| Speed: | 2933 MHz |
| Voltage: | 1.2 V |
| Feature: | no ECC Support |
Please note that in the 32-bit editions of Windows operating systems a maximum of about 3.2 GB memory is detected.You can find more information about this on the Microsoft website.
| Slot | Interface | Dimensions | Key(s) | Hints |
| 1 | PCIe x4, SATA | 2280 |
No, the graphics card is onboard (soldered).
If your notebook does not yet have a hard disk, a 2.5 inch SATA 6 Gb/s HDD can be retrofitted. Please note that the overall height must not exceed 7 mm.
Review Date: 2021-11-03
