MSN 20069774
12th Generation Intel Core i9/i7/i51
1 L3 cache varies depending on CPU
A list of compatible CPUs can be found here.There are 4 memory slots on the mainboard, each of which can hold 32 GB of RAM. The maximum capacity is therefore 128 GB.
| Module: | 288 Pin-DIMM |
| Type: | SDRAM-DDR5 |
| Clock: | 4800/4000 MHz |
| Voltage: | 1,1V |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory is recognised. You can find more information on this on the Microsoft website.
If you have not yet installed a memory, this MSI-video can help you.
| Slot | Connection | Dimensions | Key(s) | Comment |
| 1 | PCIe 4.0 x4/x2 (M2A_CPU) | 2260/2280/22110 | M Key | Intel Optane memory ready |
| 2 | PCIe 4.0 x4/x2, SATA (M2C_SB) | 2260/2280/22110 | M Key | Intel Optane memory ready |
| 3 | PCIe 4.0 x4/x2 (M2P_SB/M2Q_SB) | 2260/2280/22110 | M Key | Intel Optane memory ready |
| 4 | PCIe 4.0 x4/x2 (M2P_SB/M2Q_SB) | 2260/2280/22110 | M Key | Intel Optane memory ready |
System acceleration with Intel Optane Memory can only be enabled on M.2 ports supported by the chipset.
⚠️Note⚠️ For the fastening you need a screw with metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in the local specialist shop, you can find them in the online shop.
The front PIN assignment can be taken from the illustration.
1x PCIe 5.0 x16 slot (PCIEX16)
2x PCIe 3.0 x16 slot (PCIEX4_1, PCIEX4_2 )
Supports 2-Way AMD CrossFire technology
Article in other languages:
Review Date: 2025-02-30
