FAQ: Specifications Mainboard "GIGABYTE B760M GAMING X AX".
FAQs about the mainboard GIGABYTE B760M GAMING X AX
MSN 20071669
  • Which processors (CPUs) can be used?
    • LGA1700 socket: Support for the 14th, 13th, and 12th Generation Intel® Core™, Pentium® Gold and Celeron® Processors
    • L3 cache varies with CPU
    (Please refer "CPU Support List" for more information.)
  • What is the maximum amount of working memory (RAM) that can be installed?
  • There are four memory slots on the mainboard that holds 48 GB RAM. The maximum capacity is therefore 192 GB.
    Module: 288 Pin-DIMM
    Type: SDRAM-DDR5
    Speed: 4800 / 4000 MT/s
    Speed (O.C.): 7600 / 7400/ 7200 / 7000 / 6800 / 6600 / 6400 / 6200 / 6000 / 5800 / 5600 / 5400 / 5200 MT/s
    Voltage: 1.2 V
    Feature:
    • Support for ECC Un-buffered DIMM 1Rx8/2Rx8 memory modules (operate in non-ECC mode)
    • Support for non-ECC Un-buffered DIMM 1Rx8/2Rx8/1Rx16 memory modules
    • Support for Extreme Memory Profile (XMP) memory modules
    ⚠️Note⚠️ The 32-bit editions of Windows support / detect a maximum memory capacity of 3.2 GB. You can find more information about this on the Microsoft website.
    If you haven't installed a memory yet, this Video from MSI assists you doing it.
    The CPU and memory configuration may affect the supported memory types, data rate (speed), and number of DRAM modules, please refer to Memory Support List for more information.
  • Which M.2 cards can be used?
  • Slot Interface Dimensions Key(s) Hint
    1 PCIe 4.0 x4/x2 (M2A_CPU) 2280 M Key (internal) - M.2 SSDs with M Key or B & M Key
    2 PCIe 4.0 x4/x2 (M2P_SB) 2280/22110 M Key (internal) - M.2 SSDs with M Key or B & M Key
    Storage Support List
    ⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 to a maximum of 5 mm and be flat. If the screws are not available in local shops, you can find them in online shops (if not included in the scope of delivery).
  • What is the front pin assignment for the mainboard?
  • The front PIN assignment can be taken from the figure.
    ⚠️Note⚠️ the correct polarity, otherwise the computer may not start.
  • What do the LAN port LEDs indicate?
  • What is the assignment of the audio ports (rear)?
    You can change the function of the audio jacks using the audio software.
    Please visit GIGABYTE's website for details on configuring the audio software.
  • Which slots for graphics cards are available?
  • 1x PCIe 4.0 x16 slot (PCIEX16)
    1x PCIe 3.0 x16 slot (PCIEX4)
    If you only want to install one PCI Express graphics card, you should install it in the PCIEX16 slot for optimal performance.
  • Does the board support TPM?
  • TPM 2.0 support is available.
  • How is the board layout?
  • How do I configure a RAID Set?
  • Please visit GIGABYTE's website for details on configuring a RAID array.
Version history
Last update:
‎14.01.2025 12:10
Updated by:
Labels (2)
Contributors
