keyboard backlight not turning on
4 ANTWORTEN 4
Levi
Nachricht 1 von 5
1.040 Aufrufe
Nachricht 1 von 5
1.040 Aufrufe
I opened the control centre and I has all the correct apps, however I cant turn the backlight on, I press Fn + and it says the backlight is on but nothing changes.
I have the crawler E10 bought yesterday arrived today.
4 ANTWORTEN 4
Nachricht 2 von 5
1.033 Aufrufe
Nachricht 2 von 5
1.033 Aufrufe
Hello @Levi and welcome
which key with Fn+ do you press?
Fn+ Esc to open Control Center
bye Fishtown
Levi
Nachricht 3 von 5
1.025 Aufrufe
Nachricht 3 von 5
1.025 Aufrufe
hi and thank you, i used the correct combination and correct procedure and nothing changed.
Nachricht 4 von 5
1.002 Aufrufe
Nachricht 4 von 5
1.002 Aufrufe
Hello @Levi
If the LED keyboard setting can be adjusted in the control center and the brightness there is not at zero and the other Fn+1-12 keys also work (hot key driver)
but the LED keyboard still does not light up, then I strongly suspect a technical defect. (possibly loose ribbon cable for the keyboard lighting).
Contact Medion service for further action on the complaint.
bye Fishtown
Nachricht 5 von 5
875 Aufrufe
Nachricht 5 von 5
875 Aufrufe
HI @Levi ,
could you please give us an update on your topic? Are you still in need of any kind of assistance, or can we close this case?
Cheers
Majro ToM
4 ANTWORTEN 4
