can someone help me with this beeping ?.
5 RÉPONSES 5
jackyjoy123
Message 1 sur 6
3 652 Visites
Message 1 sur 6
3 652 Visites
Hello,
I bought the pc, the pc was keep beeping in every 10 seconds( sometimes shorter sometimes longer ), but works just fine totally.
after using about 3 months, I moved away for quiet long time and just brought back this pc and started using it again, but it's still making the beeping sound but again it works perfectly fine.
I tried to open it to clean a bit before using it.
but it seemed impossible to open ( it has only 8 cross screws and theres a lot of screws that cant rotate with screw driver. i have no idea how to remove it. it just has round hole in the middle.
but anyways the pc was quiet well covered and only has few opened space only around the fan, and when I looked inside it was just clean so I decided to just use it and it works perfectly.
its overall working perfectly but I cannot stop worrying about something might be wrong with the pc.
thanks
jackyjoy
5 RÉPONSES 5
Message 2 sur 6
3 555 Visites
Message 2 sur 6
3 555 Visites
moin @jackyjoy123 and welcome
first you should tell us what kind of device it is.
please state your MSN number
bye Fishtown
Message 3 sur 6
3 544 Visites
Message 3 sur 6
3 544 Visites
Hi @jackyjoy123
Are the beeps at intervals and regular! can you count these once.
there is a problem (exclamation mark) in the device manager!
I saw in another topic of yours that you have an x7833
to open look here:
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.youtube.com%2Fplaylist%3Flist%3DPLguVzGKGosOOg...
maybe the memory/ ram, you have two of them. take one out .. is the problem still? .. yes!
put it back in and take the other one out .. is it now without a beep?
bye Fishtown
jackyjoy123
Message 4 sur 6
3 335 Visites
Message 4 sur 6
3 335 Visites
@jackyjoy123 wrote:
Hello,
https://creditcardsupportx.com/pep-boys-credit-card/ https://creditcardsupportx.com/rooms-to-go-credit-card/ https://creditcardsupportx.com/midas-credit-card/ its overall working perfectly but I cannot stop worrying about something might be wrong with the pc.
thanks
jackyjoy
thanks my issue has been fixed.
sweetpoison
Message 5 sur 6
3 333 Visites
Message 5 sur 6
3 333 Visites
Removing the clickbait from your post might also solve some issues
Message 6 sur 6
3 323 Visites
Message 6 sur 6
3 323 Visites
Hello @jackyjoy123
please note the netiqette:
No commercial advertising
The Community is not intended as an online shop or trading platform.
You do it very skillfully, this is the second time you manipulate posts. (Copy advertising into it)
your own contribution here and that: also one who doesn't belong to you, post 7:
https://community.medion.com/t5/ERAZER-Gaming/Erazer-x7851-Control-Center/m-p/110518#M1089
that's not right that you change the posts of other users.
you have to reckon with consequences.
bye Fishtown
5 RÉPONSES 5
