X30 P64003...
5 REPLIES 5
ukguy2k
Message 1 of 6
Message 1 of 6
X30 P64003...
Where can I update the drivers from?
It has a GTX 1060 6GB dedicated graphics card already installed as when I purchased this PC.  If I want to upgrade the graphics card to a GTX 1070 8GB,  is it just done as remove the GTX 1060 6GB graphics card and install the GTX 1070 8GB Graphics card myself?
I have upgraded the memory ram to 16GB.
What PSU is the X30 P64003 PC have?
My spec:
i5-8400, 16GB DDR4 RAM, GTX 1060 6GB, 128GB SSD, 1TB Hard Drive, Windows 10 Home, DVD Writer, Gigabit Ethernet, Bluetooth, HDMI, DVI, WIFI, USB 3.0, USB 2.0.
5 REPLIES 5
Message 2 of 6
Message 2 of 6
@ukguy2k
Hi, to find answers to your question we first need the correct naming and the MSN  number, as well as the MD number.
In the database I can't find a X30 P64003.  The  correct numbers you find on the back or underneath on the bottom. I guess you are talking about an Erazer Desktop PC, right?
bye, daddle
ukguy2k
Message 3 of 6
Message 3 of 6
Hi,
Yes, It is an Erazer Desktop PC.
ukguy2k
Message 4 of 6
Message 4 of 6
Product Name: Medion Erazer P66042.
MD34258.
MSN: 10022619.
Model Name: MT28G.
Message 5 of 6
Message 5 of 6
@ukguy2k
Sorrry, I can't find any data about your PSU; I just know your Nvidia GTX 1060 has 120 W  power consumption. Compare it with the power consumption of the GTX 1070, 8 MB. I assume by roundabout 15 % more consumption your built in PSUwill be sufficient.
 You can check your PSU by opening the computer on one side, and you should check if your graphic card has a separat 4, 6 or 8 Pin power plug.
Your graphic card specs: VGA Nvidia GF GTX1060
VGA Nvidia GF GTX1060; GPU: GP106-400-A1; 6144 MB GDDR5
* Vendor: Nvidia
* Sub-Vendor: PC Partner
* Model:
* GPU: GP106-400-A1
* Chip: GTX1060
* POWER consumption 120 W
* Memory: 8008 MB GDDR5X, 192 bit
* Core Frequency: 1506 / 1708 MHz
* Memory Frequency: 2002 MHz
* Shader Frequency: - MHz
* Cores: 1280
Message 6 of 6
Message 6 of 6
Hi @ukguy2k
your PSU: MSN 20064207
Fortron FSP450-50AMDN EU/AU EUP
Form factor
: ATX Power supply unit
General specification
: 450 W
: with I/O Switch
: Power factor collector (active PFC)
Input
: 180 - 264 Vrms (AC)
: 47 - 63 Hz
: 3,5 Amp (maximum) at 200-240 Vrms/ 50 Hz
Output (maximum)
: +3.3V: 24/13.6A
: +5V: 8/15A
: +12V: 36A
: -12V: 0.3A
: +5Vsb: 3A
bye Fishtown
5 REPLIES 5
