Where can I buy a charger for my Erazer X10
1 REPLY 1
KALB321
Message 1 of 2
Message 1 of 2
Hi,
I'm looking for a charger for the following laptop;
MEDION Erazer X10-MD 61882
MSN 30029492
Product code: MSN: 40075703
I've tried buying directly from the medion shop and when requesting a tracking ID I was told the item went back to Germany from customs and I'll be issued a refund 🙃
I tried buying one from Amzazon, see following link:
https://www.amazon.co.uk/gp/aw/d/B07B6NKFWJ?psc=1&ref=ppx_pop_mob_b_asin_title
It doesn't work well when playing demanding games I get stuttering, I confirmed the charger was the issue by using my friends genuine charger and having no issue.
Please help 😿
Kal
1 REPLY 1
Message 2 of 2
Message 2 of 2
@KALB321
Try to order here. But I gues you will have to make custom-declarations. Because of  Brexit! 😀
-->  https://www.medion.com/medionserviceshop/search?sbf=true&sfs=0&msn=40075703&catchword=
230  W should be sufficient. Sure the plug dimensions are suitable? In case not, you could connect the plug from the old charger to the cable of the new one, to get a tight fit.
1 REPLY 1
