Service manual for E30 Crawler MD62445
5 REPLIES 5
Spookster
Message 1 of 6
Message 1 of 6
Hi there people, thanks for help in advance but is there such a thing as a service manual for this model?, may want to upgrade later and also wondering about spec inside if there's 2 rams slots, 1 or 2 SSD slot etc?
Any help greatly appreciated.
1 ACCEPTED SOLUTION
Message 2 of 6
Message 2 of 6
Hi @Spookster and welcome
You have a Crawler MD62445 MSN 30033973 ,
Unfortunately, I can't find it in the database with its specifications.
all other crawler E30 are a barebone clevo NP50 PNJ/PNH or PNK so I assume yours is one of them. You can find a service manual here:
https://www.file-upload.net/download-15137348/NP50PNHPNJPNKSM.zip.html
you have two M.2 SSD PCIe slots:
One M.2 PCIe Gen4 x4 Solid State Drive (SSD)
One M.2 PCIe Gen3 x4 Solid State Drive (SSD)
Unfortunately, I can't tell you which one is already occupied in your case.
bye Fishtown
5 REPLIES 5
Message 2 of 6
Message 2 of 6
bye Fishtown
Spookster
Message 3 of 6
Message 3 of 6
That's excellent my friend and thanks so much for the quick help really appreciate it. 😀
Message 4 of 6
Message 4 of 6
@Fishtown
Ist doch hier mit den Tech Specs gelistet, und auch im Intranet:
-->  https://www.medion.com/de/service/product-detail/30033973
Oder ist die Übersetzung  ins Englische missglückt?
"Unfortunately, I can't find it in the database with its specifications,
all other crawler E30 are a barebone clevo NP50 PNJ/PNH or PNK"
Denn das sagt aus du hättest den Crawler mit den angegebenen MD und MSN Nummern  nicht gefunden.
Und ja, es ist ein " NB BB CLV NP50PNJ-M Crawler E30 ERAZER bk"
Gruß, daddle
Message 5 of 6
Message 5 of 6
Moin @daddle
Du vergisst dabei den Faktor "Zeit"
Der Beitrag ist 1,5 Jahre her und zu dem Zeitpunkt war es so. Wenn es danach in die Datenbank eingefügt würde um so besser.
Message 6 of 6
Message 6 of 6
@Fishtown
Daa war ja keine Kritik, sondern eine Ergänzung. Um so besser wenn zwischendurch der Rechner in der Datenbank eingepflegt wurde.
Das war nicht der Hauptpunkt; Eine geschíckte Ablenkung vom Hauptteil meines Posts, die Tatsache, dass du im Englischem das Gegenteil von dem was du sagen wolltest im Engischem ausgedrückt hattest.  Aber da gehst du gepflegt drüber hinweg.
Du kannst solche Fehler vermeiden, wenn du die Google Übersetzung, oder die eigene Englisch Kreation in den Google Übersetzer zur Kontrolle in umgekehrter Richtung, also in:
Fremdsprache  -->  German, eingibst. Dann erkennt man solche logischen Brüche, oder falsche Zuordnungen oder Sinnverdrehungen direkt.
Und ja, das Datum hatte ich auf dem kleinem Handyschirm nicht kontrollert. Schmälert aber nicht  den Inhalt meines Posts.
Gruß, daddle
Edit: Typo
5 REPLIES 5
