Please help for my motherboard upgrade !!
5 REPLIES 5
kaanozkans
Message 1 of 6
Message 1 of 6
Hello guys,im new at this community and i need youre help please.
i did buy medion erazer 57001gaming desktop pc but i will upgrade my cpu cooler and ssd.will it be a problem if i put an samsung 970 evo m2 ssd on my motherboard or wich ssd should i buy and wich cpu cooler?? can you guys help me please.
my motherboard model number is B550A4-EM
5 REPLIES 5
Gehringer
Retired
Message 2 of 6
Message 2 of 6
Hi @kaanozkans and welcome to the forum.
Can you please provide the MSN number of your product?
It is an 8-digits number printed in the label underneath your product.
It normally starts by 500 or 300.
Regards,
Gehringer
kaanozkans
Message 3 of 6
Message 3 of 6
Hı gehringer,sure thing here you go
MD number : 34664
MSN number : 10023368
Message 4 of 6
Message 4 of 6
Hi @kaanozkans
the mainboard MB ECS B550A4-EM has one
1x M.2 SSD (2260 and 2280) PCIe  Slot, the other is for WiFi
I can't tell you more because I can't find the pc,
@Gehringer will surely know more.
bye Fishtown
kaanozkans
Message 5 of 6
Message 5 of 6
Thanks for youre support !! Im still waiting for @Gehringer reply for help
Gehringer
Retired
Message 6 of 6
Message 6 of 6
Hi @kaanozkans , thanks for your patience.
@Fishtown is correct regarding your MB.
Unfortunately I can't advise you on which SSD or cooler to buy because that is your personal choice.
If you are unsure, I would suggest you provide your NB and your MB models to the seller and ask if their product is compatible.
I would also choose resellers which offer a flexible return policy just to be on the safe side.
Best regards,
Gehringer
5 REPLIES 5
