Part number for fan replacement for Medion deputy p30 MD62446
2 REPLIES 2
BTV
Message 1 of 3
Message 1 of 3
Hi, I hope you're well.
One of the fans exhausting the laptop tries to spin up, mades a horrible grating sound and stops, I've tried cleaning the fan, disconnecting and reconnecting it but nothing has improved its ability to function.
Does anyone know how I would get a part number for the fan, short of taking apart the whole underside of the laptop?
I'm hoping to to replace the fan but I don't want to remove the fan enclosure if it's going to remove the heat pipes aswell, does anyone have a teardown guide or a schematic(not sure if that's the right word) for the laptop?
I don't have any thermal paste to hand so don't want to get halfway though the process and realise I can't get any further solving the issue, or be stuck unable rebuild the laptop without applying fresh paste.
Thanks in advance.
Tags (2)
2 REPLIES 2
Igor28
Message 2 of 3
Message 2 of 3
Hi @BTV ,
Do you have the MSN reference of the laptop? According to this reference, the fan could be found on Medion Service Shop
Thanks
BTV
Message 3 of 3
Message 3 of 3
Hi Igor,
The msn is:
30034001
I've checked the service shop but it says nothing is available.
2 REPLIES 2
