op 16.01.2025 19:48
op 16.01.2025 19:48
Hi, I hope you're well.
One of the fans exhausting the laptop tries to spin up, mades a horrible grating sound and stops, I've tried cleaning the fan, disconnecting and reconnecting it but nothing has improved its ability to function.
Does anyone know how I would get a part number for the fan, short of taking apart the whole underside of the laptop?
I'm hoping to to replace the fan but I don't want to remove the fan enclosure if it's going to remove the heat pipes aswell, does anyone have a teardown guide or a schematic(not sure if that's the right word) for the laptop?
I don't have any thermal paste to hand so don't want to get halfway though the process and realise I can't get any further solving the issue, or be stuck unable rebuild the laptop without applying fresh paste.
Thanks in advance.
op 29.01.2025 10:02
op 29.01.2025 10:02
Hi @BTV ,
op 30.01.2025 17:22
op 30.01.2025 17:22
Hi Igor,
The msn is:
30034001
I've checked the service shop but it says nothing is available.
