PC Erazer Beast X30 doesn't boot anymore
21 REPLIES 21
Welshcheese
Message 1 of 22
Message 1 of 22
Hi
My Erazer Beast X30 PC doesn't start anymore, I have been away for 3 days, which is the longest time it has not been used since purchase.
With the power supply plugged in the charge light does not light or flash
While I tap on the power button :
- The power led lights up white for 25 seconds
- No fan noise, nothing shown on the PC screen
- After 25 seconds the keyboard backlight turns on for 1 second then keyboard and power buton lights turn off automatically.
What I have tried:
Keeping the POWER button pressed for 30 seconds, but it doesn't help 😕
Pressing the power button once, and when the button light is white,
then pressing and holding the power buton, this just turns the light on the button off after about 13 seconds.
I have 2 power supplies and both have the same result, and both have 19.5v at the tip shown using a multimeter.
What can I do?
Thank you in advance for your help,
Nigel
21 REPLIES 21
Welshcheese
Message 21 of 22
Message 21 of 22
Hi
The response from Medion after ,
"Thank you for contacting us.
After assessing your unit we require a motherboard for the repair unfortunately the part is unavailable"
I had never used Eco Mode, as my laptop was used in an office plugged in to the AC adapter or at home plugged in to the AC adapter.
Thanks for the information though,
Welshcheese
Message 22 of 22
Message 22 of 22
Hi
The response from Medion after sending the dead laptop to them was:
I had never used Eco Mode for the battery, never used it on battery as only lasted about 40 minutes playing games, my laptop was used in an office, plugged in to the AC adapter or at home plugged in to the AC adapter.
Thanks for the information though for others to try, but I would not advise people to dismantle the device if it is still under warranty/guarantee as this may void it.
21 REPLIES 21
