PC Erazer Beast X30 doesn't boot anymore
21 REPLIES 21
Welshcheese
Message 1 of 22
Message 1 of 22
Hi
My Erazer Beast X30 PC doesn't start anymore, I have been away for 3 days, which is the longest time it has not been used since purchase.
With the power supply plugged in the charge light does not light or flash
While I tap on the power button :
- The power led lights up white for 25 seconds
- No fan noise, nothing shown on the PC screen
- After 25 seconds the keyboard backlight turns on for 1 second then keyboard and power buton lights turn off automatically.
What I have tried:
Keeping the POWER button pressed for 30 seconds, but it doesn't help 😕
Pressing the power button once, and when the button light is white,
then pressing and holding the power buton, this just turns the light on the button off after about 13 seconds.
I have 2 power supplies and both have the same result, and both have 19.5v at the tip shown using a multimeter.
What can I do?
Thank you in advance for your help,
Nigel
21 REPLIES 21
Message 11 of 22
Message 11 of 22
@Welshcheese
What a stupid mess is this now? How do you suddenly know on a sunday evening? Your picture will only be seen for other users tomorrow morning, after it is approved by a moderator.
But tell me where are you from? GB, or another country?
Depending in which country you are, guarantee procedures will be different.
Because i cannot see the picture yet, please state  the MSN  number ( 8 digits, beginníng with 300 .....) and the MD-number. Both should be seen on a sticker on the bottom of the case.
I am sure we can find it here.
Welshcheese
Message 12 of 22
Message 12 of 22
@daddle
yes it is a mess, lol
I am in the UK, the details of my laptop are
NB ERAZER BEAST X30 MD62452 UK
MSN: 30033995
Message 13 of 22
Message 13 of 22
@Welshcheese
I cannot find yout Laptop with this MSN or MD nummber either, nor on the service pages, nor inside the small medion database Superuser have access to.
So it seems that in the UK market Medion PCs have a different number range than in  Germany.
It seems for guarantee service only your shop who sold this PC is responsible.
Was it your opinion to say it would be better to handel your guarantee matters with Medion directly? Or did you contact your shop on sunday
I do think first address concerning the guarantee of your Beast X30 in England normally is your dealer. But I am not sure about this.
I would be interested what has happened before the three days you have been away? Did you get a bios update?
Did the  laptop stayed on while you were away? Or switched off but connected to the charger?
May be a short in your Home AC circuit happened inbetween, or a lightning bolt caused a voltage surge.
Did you contact inbetween and your reported to the shop where You  purchased your Beast?
Cheers, daddle
@Major_ToM
Es sieht hier nach einem nicht so einfach zu lösendem Problem mit einem  NB ERAZER BEAST X30 MD 62452 UK aus.
MSN: 30033995.
Diese Nummer finde ich nicht in unserem Intranet oder der Service Seite nicht.  Wie könnte der User @Welshcheese weiter vorgehen, wenn sein Retailer ihm sagt er möge sich an Medion direkt  wenden?
Siehst Du da eine Möglichkeit?
Hat sich geklärt! Danke für  die Aufmerksamkeit, den Post zu lesen.
Gruß, daddle
Welshcheese
Message 14 of 22
Message 14 of 22
Hi @daddle
I phoned Medion UK support today, and they are collecting the laptop tomorrow.
The shop where I purchased it were happy to deal with it, but this would mean sending it to them to send to Medion, and the return trip would be through them.
The said I will get it back sooner, if I deal with Medion directly.
The laptop was completely unplugged while I was away, so nothing was plugged in to the laptop to cause an issue.
Nothing updated, I just shut it down at night as I was leaving at 7am, unplugged everything and moved to a different room so not on display if anyone looked through the window.
Thanks again for all the help
Message 15 of 22
Message 15 of 22
@Welshcheese
@Welshcheese  schrieb:
Hi @daddle
That's great. Congratulations.
I did remember another guarantee case, in which was said for those events Medion does not support in England, the local dealer alone was responsible.
But I guess with the high prized Erazer models, they have a different approach to it. Good for you.
May be my
Please let me know the outcome, rp. the reason for the breakdown.
Cheers, daddle
Welshcheese
Message 16 of 22
Message 16 of 22
@daddle
They found the motherboard had failed, and did not have a spare, so they replaced the entire computer with a different one, and sent my drive back with it so I could recover my files
Message 17 of 22
Message 17 of 22
@Welshcheese
Thanks for the feedback. That's good news.. Which model did you get  in exchange?
Welshcheese
Message 18 of 22
Message 18 of 22
Hi @daddle
It was replace with an X40 Beast
Welshcheese
Message 19 of 22
Message 19 of 22
@daddle
I went from being sad to happy when I was offered a newer model to replace the older one.
Well done Medion, this is why I have been using you for the last 8 years.
bw11195
Message 20 of 22
Message 20 of 22
I understand you have solved the problem by sending the laptop to Medion, but I do wonder if it was caused by you setting the battery profile to Eco mode. Once shut down with eco mode switched on, the laptop will refuse to boot and will show only the power LED until it switches itself off.
For posterity reasons, here is how to resolve this issue (for people who know that they turned the eco battery profile on) without going to support;
Unplug laptop,
Open the bottom panel,
Unplug battery,
Remove battery by removing the 3 screws,
Unplug the CMOS battery (it is the twisted red and black cable),
Plug in mains power from your charger,
Your laptop should now boot, go into control centre and switch your battery profile to balanced,
Follow the above instructions in reverse to reassemble your laptop back to normal.
Please note that even using third party control center software (such as XMG) still causes this issue and thus I believe it is a BIOS issue but i have not installed a third party BIOS on my laptop to test.
21 REPLIES 21
