P7651 RAM Upgrade
4 REPLIES 4
Slartibardfast
Message 1 of 5
Message 1 of 5
P7651 RAM Upgrade
Will this Unit take 2 x 16GB DDR4 3200 MHz Sodimm Modules?
Thanks again.
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 4 of 5
Message 4 of 5
Hi @Slartibardfast ,
your original RAM specs is the following:
1x 8192 MB DDR4 SO-DIMM (PC4-19200 / 2400 MHz)
(1/2 occupied, 16 GB max.)
As mentioned, it is upgradable until 16GB max.
Regards,
Gehringer
4 REPLIES 4
Gehringer
Retired
Message 2 of 5
Message 2 of 5
Hi @Slartibardfast , welcome to the Forum.
Could you please provide me your product's MSN number so I can help you further with this question?
Regards,
Gehringer
Slartibardfast
Message 3 of 5
Message 3 of 5
30023348
Gehringer
Retired
Message 4 of 5
Message 4 of 5
Regards,
Gehringer
Slartibardfast
Message 5 of 5
Message 5 of 5
That's a pity, but it's not a pressing need just a nice to have.  I have 16GB installed so am at the limit.
Btw it did not come with 1 x 8GB Module but 2 x 4GB Modules installed.
And thanks for checking for me.  Saved making an expensive mistake 😉
4 REPLIES 4
