Open Erazer X6603 to upgrade memory and ssd.
2 REPLIES 2
TheoVliet
Message 1 of 3
Message 1 of 3
Hi does anyone know where to find a manual with details how to remove back cover or did it himself
I removed all screws but then it is still stuck and not easy to remove I am afraid housing will break
I ahave opened a lot of laptops before but that where business laptops HP and Lenovo and there the material is much tougher.
2 REPLIES 2
DarkKnight
Message 2 of 3
Message 2 of 3
Hi @TheoVliet
The manual for this unit can be found at https://www.medion.com/gb/service/_lightbox/handbuch_details.php?did=17018.
This does not show how to remove the cover but it if you are using a generic plastic case removal tool then the internal clips should be easily opened for the removal of case. This is only meant to be done by experienced technician.
Hope this helps.
@DarkKnight
Muppet31
Message 3 of 3
Message 3 of 3
Hi, new member, just got this laptop and was thinking about upgrades too, did you manage to get the back panel off easily? Thanks
2 REPLIES 2
