Medion Illuminated Gamming Keyboard P81035 Not working with Windows 10 Pro
2 RÉPONSES 2
rmonroe
Message 1 sur 3
2 715 Visites
Message 1 sur 3
2 715 Visites
Hi all,
The Keyboard worked correctly, but then I had a SSD failure and replaced it. Upon reinstalling Windows 10 Pro the Keyboard did not work right. Keys not working when pressed or lagged - needed to wait 5 seconds to show on the screen. Some times the key would keep typing while not pressed until I waited the 5 seconds and then pressed a key to stop it. I went to the website in the manual to download the software again for the keyboard to try and fix this issue, but the website was not available.
(The requested URL /downloads/software/illuminated_keyboard_MD850310.exe was not found on this server.)
Here is the link:
http://cdn.medion.com/downloads/software/illuminated_keyboard_MD850310.exe
I was able to find a version for the software here:
https://download.medion.com/downloads/treiber/illuminated_keyboard_MD85031.exe
After install and reboot the same problems persisted.
Is there a solution available?
Thank you all
Roy
1 SOLUTION APPROUVÉE
Solutions acceptées
Gehringer
Retired
Message 2 sur 3
2 703 Visites
Message 2 sur 3
2 703 Visites
Hi @rmonroe ,
please go to Medion USA website here and perform a search using your model (MD) number 85031.
Then, click on "Driver Software Gaming Keyboard MEDION MD 85031" to expand the list of options and right-click over the red download banner.
Select the option "Save the link as" and save it on your unit.
Run the file and install the drivers.
Regards,
Gehringer
2 RÉPONSES 2
Gehringer
Retired
Message 2 sur 3
2 704 Visites
Message 2 sur 3
2 704 Visites
Hi @rmonroe ,
Regards,
Gehringer
rmonroe
Message 3 sur 3
2 689 Visites
Message 3 sur 3
2 689 Visites
Thank you so much. That worked!
2 RÉPONSES 2
