Medion Erazer X25 doesn't use the Fan until manually diseabled.
1 ANTWOORD 1
McBenji
Bericht 1 van 2
1.135 Weergaven
Bericht 1 van 2
1.135 Weergaven
Yeah, my laptop doesnt use the fans, no matter how high the temperature. This is very annyoing as the only way to cool the laptop now is enabling fan boost in control center which is very loud for normal use.
1 ANTWOORD 1
JacobP
Bericht 2 van 2
1.016 Weergaven
Bericht 2 van 2
1.016 Weergaven
Hello there @McBenji ,
I expect there are some settings we can change to fix this problem. So we know the exact model of your unit can you find the MSN number of your unit. Its usually on the base of the laptop.
1 ANTWOORD 1
