on 29.01.2024 18:18
on 29.01.2024 18:18
hi, Is there a way to enter the advance bios to have access to settings for the cpu to change the power settings and IGP? I live in the caribbean(tropics) and my processor gets too hot?
on 29.01.2024 20:25
on 29.01.2024 20:25
Hi,
you can Enter Bios y pressing F2 tab while starting. Therein you can deactivate the dedicated graphic card (Intel Arc) by IGD only.
In Windows settings (energy) you can reduce the processor frequency in percentage steps.
Here is the manual: --> https://cdn.medion.com/cdn/download.pl?lang=de&filename=bda_x10_major_en.pdf&id=22775&type=anleitung...
Cheers, daddle
on 30.01.2024 17:02
on 30.01.2024 17:02
Hi, further is there a way to access these settings in the bios, like advance tab? i cant change any cpu setting in bios
Since i installed the latest bios my cpu overheats 101 degrees when gaming.
Thanks
on 30.01.2024 17:19
on 30.01.2024 17:19
Then why don't you check the menu items in the Advanced tab yourself? But except from activating different cores I don#t know how to limiit te CPU in Bios.
