Medion Erazer Major x10 laptop advance bios, to change power limits
3 ANTWORTEN 3
tr3thesl4yer
Nachricht 1 von 4
1.076 Aufrufe
Nachricht 1 von 4
1.076 Aufrufe
hi,  Is there a way to enter the advance bios to have access to settings for the cpu to change the power settings and IGP? I live in the caribbean(tropics) and my processor gets too hot?
3 ANTWORTEN 3
Nachricht 2 von 4
1.062 Aufrufe
Nachricht 2 von 4
1.062 Aufrufe
@tr3thesl4yer
Hi,
you can Enter Bios y pressing F2 tab while starting. Therein you can deactivate the dedicated graphic card (Intel Arc) by IGD only.
In Windows settings (energy) you can reduce the processor  frequency in percentage steps.
Here is the manual: --> https://cdn.medion.com/cdn/download.pl?lang=de&filename=bda_x10_major_en.pdf&id=22775&type=anleitung...
Cheers, daddle
tr3thesl4yer
Nachricht 3 von 4
1.032 Aufrufe
Nachricht 3 von 4
1.032 Aufrufe
Hi, further  is there a way to access these settings in the bios, like advance tab? i cant change any cpu setting in bios
Since i installed the latest bios my cpu overheats  101  degrees when gaming.
Thanks
Nachricht 4 von 4
1.028 Aufrufe
Nachricht 4 von 4
1.028 Aufrufe
@tr3thesl4yer
Then why don't you check the  menu items in the Advanced tab yourself? But except from activating different cores I don#t know how to limiit te CPU in Bios.
3 ANTWORTEN 3
