Medion Erazer Engineer P10 MD35036 crashes then reboots....
11 REPLIES 11
grejon
Message 1 of 12
Message 1 of 12
This has happened several times now since I have the PC, it will crash and reboot at random times. Once a day or every couple of days.
I checked the eventlog and I get 2 problems, one is "PC restarted after bugcheck", the other is a kernal-power issue.
I've seen posts from other people that have a similar issue so I'm guessing it's related.
MSN: 10024042
1 ACCEPTED SOLUTION
Message 11 of 12
Message 11 of 12
Hi @grejon
from the last link (Message 8 )
try it : https://www.file-upload.net/download-14815948/bios_b560h6-em_v21.zip.html
Editing your post again is easy. go to these and on the top right on the three dots. Click on "Edit Reply" there and you can edit your post again. note: accessing and editing is limited in time. after that it is no longer possible. try it.
bye Fishtown
11 REPLIES 11
grejon
Message 2 of 12
Message 2 of 12
I saw that some people recommend to update the bios so I would like to try that. Unfortunately I am unable to download the bios files or any of the manuals on https://www.medion.com/gb/service/product-detail/10024042. Whenever I click the download link, it opens up a new page that never loads. I've tried different browsers but none of them seem to work
Message 3 of 12
Message 3 of 12
Hi @grejon
tested
http://bda.medion.com/bda_20069621.pdf
https://cdn.medion.com/cdn/download.pl?lang=de&filename=bios_b560h6-em_v21.zip&id=21848&type=softwar...
bye Fishtown
edit: http://www1.medion.de/downloads/index.pl?op=detail&id=21848&type=software&lang=uk
grejon
Message 4 of 12
Message 4 of 12
Hi @Fishtown
Neither link seems to be working for me, first link gives me a blank page while the second one works but pressing "download" gives me a blank page again, after it just says "site cannot be found". Very weird, I have no idea why it doesn't work
Message 5 of 12
Message 5 of 12
Hi @grejon
and the one I added as a supplement? does that not work either?
bye Fishtown
grejon
Message 6 of 12
Message 6 of 12
@Fishtown The user manual PDF works. The second link does not, the third link works until I press "download" then it gives me a blank page.
Message 7 of 12
Message 7 of 12
Hi @grejon
(link two and three is the same)
try with the mobile phone or tablet, that works mostly if not tell me then I upload it (but then it takes a moment)
bye Fishtown
Edit: https://community.medion.com/t5/kb/en/ta-p/121863
Message 8 of 12
Message 8 of 12
Hi @grejon
did it still work?
or do I still have to upload the link?
bye Fishtown
grejon
Message 9 of 12
Message 9 of 12
@ fishtown Can't get it to work so it would be better if you uploaded it.
grejon
Message 10 of 12
Message 10 of 12
@Fishtown sorry I don't know how to edit posts
11 REPLIES 11
